by GL.iNet
Original price CAD 560.99 - Original price CAD 560.99
CAD 560.99
CAD 560.99 - CAD 560.99
Current price CAD 560.99
⚠️Before You Buy
Puli AX (GL-XE3000)
GL-XE3000 Secure Remote VPN Connectivity
MEET Puli AX
Wi-Fi 6 5G Cellular Router with Battery
Portable Wi-Fi 6 5G NR Router
Puli AX (GL-XE3000) is the ultimate Wi-Fi 6 5G Cellular Router that takes your internet speed to the next level! With a powerful built-in 6400mAh/7.4V/47.4Wh battery, you can now enjoy uninterrupted internet connectivity for even longer periods. Experience lightning-fast Wi-Fi speeds of up to 574Mbps (2.4GHz) and 2402Mbps (5GHz), with a combined maximum Wi-Fi speed of 3000Mbps. It is equipped with a 5G NR cellular connection, ensuring reliable Internet connectivity, even in the event of an Ethernet failure.
Max. 574 Mbps (2.4GHz) + 2402 Mbps (5GHz) Fast Wi-Fi Speeds
OpenVPN speed up to 150 Mbps; WireGuard speed up to 300 Mbps
Dual-SIM, Single Modem
Built-in 6400mAh/7.4V/47.4Wh battery
Learn More
Module: RM520N-GL
5G NR NSA n1/ 2/ 3/ 5/ 7/ 8/ 12/ 13/ 14/ 18/ 20/ 25/ 26/ 28/ 29/ 30/ 38/ 40/ 41/ 48/ 66/ 70/ 71/ 75/ 76/ 77/ 78/ 79
LTE LTE-FDD B1/ 2/ 3/ 4/ 5/ 7/ 8/ 12/ 13/ 14/ 17/ 18/ 19/ 20/ 25/ 26/ 28/ 29/ 30/ 32/ 66/ 71
LTE-TDD B34/ 38/ 39/ 40/ 41/ 42/ 43/ 48
LAA B46
UMTS WCDMA B1/ 2/ 4/ 5/ 8/ 19
GNSS GPS/ GLONASS/ BDS/ Galileo/ QZSS
Reliable and Uninterrupted Internet
Puli AX (GL-XE3000) is equipped with advanced features, including Multi-WAN, Load-balancing, and Failover, to ensure users experience quality internet connections when traveling in both rural and urban areas.
Dual-SIM
Dual-SIM Standby
Dual-SIM for ISP selection
Puli AX has a dual-SIM slot design, allowing it to connect to the ISP with a stronger connection. The design ensures that the network connection is always available & reliable.
Multi-WAN
Multi-WAN
Enhanced Bandwidth and Network Stability
Puli AX's Multi-WAN technology lets users utilize multiple connection methods, including Ethernet, Repeater, Cellular, and Tethering, at the same time, increasing the total bandwidth and staying connected when a single connection type is down.
Load-balancing
Load-balancing
Optimal Bandwidth Usage
Puli AX's Load-balancing capabilities let users distribute bandwidth by custom proportion among multiple connection methods, prioritizing data consumption among preferred connection types, and minimizing network congestion.
Failover: Uninterrupted Connection
Failover
Puli AX supports Network Failover and the option to configure Failover priorities among multiple connection methods. If the primary connection fails, the router will automatically switch to the next connection method without interruption.
Smart Charging & Battery Protection
  • Temperature control: Automatically stops charging at extreme temperatures (≤0°C or ≥50°C), resumes when safe.
  • Efficient charging management: Auto-stops after full charge to protect the battery.
Puli AX is pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically encrypts all network traffic within the connected network, including guest or client devices that are not capable of running VPN. Puli AX can also host VPN servers and supports VPN Cascading, automatically forwarding data from its VPN server to the VPN client within the same device.
WireGuard
Max. 300Mbps
OpenVPN
Max. 150Mbps
Puli AX runs on GL.iNet's latest SDK4.0+ firmware and presents a user-friendly interface for common users to set up the router with minimal inputs, and an extended customization experience for advanced users to install plug-ins and applications. Puli AX runs on GL.iNet's proprietary firmware based on OpenWrt (v21.02 Kernel version 5.4), supporting more than 5,000 ready-made plug-ins for customization. Simply browse, install, and manage packages with our no-code interface within the Admin Panel.
Experience seamless connectivity with the Puli AX, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
DFS Certification in US, CA, EU and UK
Puli AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications. The selection of additional channels can lower network congestion under high density network environments.
Remote Access and Management
Puli AX comes with GL.iNet's GoodCloud remote device management platform, providing users with data usage monitoring and technical support services with remote access to the device admin panel for maintenance and troubleshooting. It also enables batch device management, firmware updates, analytics and notifications for status updates, enabling users to manage devices efficiently.
Model Comparison
Puli / GL-XE300
4G LTE Smart Router
VS
Puli AX / GL-XE3000
Wi-Fi 6 5G Router
Qualcomm Atheros, @650MHz CPU MediaTek Dual-core, @1.3GHz
DDR2 128MB / NOR Flash 16MB + NAND Flash 128MB Memory / Storage DDR4 512MB / eMMC 8GB
IEEE 802.11b/g/n Protocol IEEE 802.11a/b/g/n/ac/ax
300Mbps (2.4GHz) Wi-Fi Speed 574Mbps (2.4GHz), 2402Mbps (5GHz)
10/100Mbps Ethernet Speed WAN Port: 10/100/1000/2500Mbps
LAN Port: 10/100/1000Mbps
1 x WAN, 1 x LAN Ethernet Ports 1 x 2.5Gbps WAN, 1 x LAN
Type-C, 5V/2A Power Port DC5521, 12V/2.5A (5.5*2.1mm) [default adapter] / 9~16V
3.7V/5000mAh/18.5Wh Built-in Battery 7.4V/6400mAh/47.4Wh
1 x Nano SIM card slot SIM Card Slot 2 x Nano SIM card slots
Max.10Mbps OpenVPN (Via Ethernet) Max.150Mbps
Max. 38Mbps WireGuard® (Via Ethernet) Max. 300Mbps
Puli AX (GL-XE3000) Reivews
  • Video 0
    Best SIM Routers of 2023 - GET IT RIGHT FIRST TIME!
  • Video 1
    THE ULTIMATE SIM ROUTER DOES EXIST - The GL.iNet Puli AX Mobile Router Review
  • Video 2
    I have 5 hours to fix the gaming mini van
    5G NR Module
    5G NR
    Module
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    Wi-Fi 6
    Wi-Fi 6
    VPN Client/Server
    VPN Client /
    Server
    AdGuard
    AdGuard
    Dual-SIM
    Dual-SIM
    External Storage
    Built-in Battery
    (6400mAh/7.4V/47.4Wh)
    DFS
    DFS
    The cellular feature in Puli AX (GL-XE3000) is restricted in Russia, Belarus, Cuba, Iran, North Korea, Syria, and the Crimean Peninsula due to modem limitations.
    • CPU: MediaTek Dual-core, @1.3GHz
    • Memory / Storage: DDR4 512 MB / eMMC 8GB
    • Antennas: 4 x Cellular Antennas (SMA, 600M~6GHz), 2x Wi-Fi Antennas (PR-SMA, 2.4G~2.5GHz, 5.15~5.84GHz)
    • Cellular: 5G NR
    • Battery: 6400mAh/7.4V/47.4Wh
    • TF Card Slot: Max.1TB
    • USB Port: USB2.0 Type-A
    • Ethernet Speed: WAN Port: 10/100/1000/2500Mbps LAN Port: 10/100/1000 Mbps
    • Power Input: DC5521, 12V/2.5A (5.5*2.1mm) [default adapter] / 9~16V
    • Power Consumption: <14W
    • Dimension / Weight: 155 x 95 x 49mm / 761 g
    • 1 x Puli AX (GL-XE3000) Router
    • 1 x Power Adapter + 4 Converters (US, EU, UK & AU)
    • 2 x Wi-Fi Antennas
    • 4 x Cellular Antennas
    • 1 x Ethernet Cable
    • 1 x User Manual
    • 1 x Thank you card
    • 1 x Wall Mount Kit
    Frequently Bought Together🎁
    Product Initial Setup Guide
