Limited-Time Flash Sale: Save Up to 20%!
Travel Gadget Organizer Pouch Case | Hard Drive Bag | For chargers, cables, travel routers
by GL.iNet
Original price CAD 17.90 - Original price CAD 17.90
CAD 17.90
CAD 17.90 - CAD 17.90
Current price CAD 17.90
Color: Blue
⚠️Before You Buy
The best travel organizer for electronics! Hard Carrying Case replacement for GL-BE3600, GL-MT3000, GL-AXT1800, GL-MT1300, GL-SFT1200, GL-E750, GL-X750V2, GL-AR750S, GL-MT300N-V2, and GL-AR300M. Perfect for travel, keep your devices organized.
Product Description
• Features: Case is made of supreme quality, durable EVA, crush resistant, anti-shock, water resistant material provides adequate protection from bumps, scratches and splashes.
• With Internal mesh pocket can store other accessories.
• Internal Dimension: 5.9 x 4.3 x 2.7 inch, External Dimension: 6.3x 4.7 x 2.8 inch
• Durable Exterior Material: Polyester Fiber with soft pad inserted. The durable material can protect the device and accessories inside. The protection from the soft pad reduces the impact of falling and shocks.
Physical Features
• Colour: Grey/Black
• External Size: 16.2cm*11.8cm*6.9cm / 6.3in*4.7in*2.8in (L*W*H)
  • CPU: N/A
  • Memory / Storage: N/A / N/A
  • Protocol: N/A
  • Wi-Fi Speed: N/A
  • Antennas: N/A
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: N/A
  • Ethernet Port: N/A
  • Ethernet Speed: N/A
  • Power Input: N/A
  • Power Consumption: N/A
  • Dimension / Weight: 16.2cm*11.8cm*6.9cm / 6.3in*4.7in*2.8in (L*W*H) / 138 g
  • A bag
Product Initial Setup Guide
