Limited-Time Flash Sale: Save Up to 20%!
Puli (GL-XE300) 4G LTE Wireless Security Gateway with EC25-AF Module
by GL.iNet
Original price CAD 164.99 - Original price CAD 164.99
CAD 166.99
CAD 166.99 - CAD 166.99
Current price CAD 166.99
⚠️Before You Buy
Puli / GL-XE300
GL-XE300 4G LTE Wireless Router
MEET PULI
4G LTE Portable Wireless IoT Gateway
Puli (GL-XE300) is a portable 4G smart router that is perfect for home, business and IoT solution. With its OpenWrt supported feature and large storage compatibility, it is designed for you to develop DIY IoT project. It also comes with a rechargeable battery, so you can bring it anywhere with you!
300 Mbps Wi-Fi Speed
512GB Max MicroSD
Built-in 5000mAh Battery
Built-in BLE Module (Optional)
Learn More
LTE
Interchangeable Module Tailored to Your Needs
Puli (GL-XE300) router is easily configurable and has a built-in interchangeable module for full optimization. It is compatible with CAT4 and CAT6 modules, which with different downstream throughput and different bands to satisfy your various requirements.
LTE
IPv6 and WPA3 Supported
Puli (GL-XE300) supports the latest version of the Internet Protocol (IPv6), adding an extra layer to your cybersecurity. It also supports WPA3 encryption which is the next generation of Wi-Fi security.
Work or Play Securely Anywhere, and Anytime
Apart from its powerful built-in firewall, Puli (GL-XE300) also supports OpenVPN, WireGuard® and customized DNS server in order to level up your online security. With our brand-new Web UI 3.0, you can set up VPN server easily and access your files securely and remotely.
WireGuard® is a registered trademark by Jason A.Donenfeld.
WireGuard
Max.38Mbps
OpenVPN
Max.10Mbps
Web UI
Cloudflare
ENCRYPTED DNS WITH CLOUDFLARE
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. It serves to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Cloudflare X GL.iNet
Experience seamless connectivity with the Puli※, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
※Products with Quectel EP06-A modules do NOT support eSIM, as the Qualcomm software lacks specific AT command support. For products with EP06-E modules, please refer to this LINK to upgrade to the latest firmware and enable eSIM functionality.
Easy Configuration with New Web UI 3.0
The built-in 4G modem supports AT command, manual/automatic dial number, SMS checking and signal strength checking for better management and configuration.
AT Command
AT Command
Manual/Automatic Dial Number
SMS checking
SMS checking
Signal Strength Checking
Web Admin Panel
Puli (GL-XE300) Reviews
  • Video 0
    Sim Eiotclub provata con il router OpenWrt GL.iNet GL-XE300
  • Video 1
    Trying #EIOTClub SIM Cards Off Grid & Underground
  • Video 2
    Sim Eiotclub router OpenWrt GL.iNet GL-XE300 Proviamoli insieme
  • Video 3
    A FREE Reolink for You! EIOTCLUB Prepaid Sim Card, BizGlobeLink, Mobile Hotspot, loT 4G/5G Data
  • Video 4
    Eiotclub Travel Router with 24GB SIM Card & GL-XE300 Global Router Bundle
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    External Storage
    4G LTE
    Module
    External Storage
    Built-in Battery
    (5000mAh)
    External Storage
    External Storage
    Dual Flash
    Dual Flash
    VPN Client/Server
    VPN Client /
    Server
    • CPU: QCA9531, @650MHz SoC
    • Memory / Storage: DDR2 128MB / NOR Flash 16MB + NAND Flash 128MB
    • Protocol: IEEE 802.11b/g/n
    • Wi-Fi Speed: 300Mbps (2.4GHz)
    • Antennas: 2 x Internal Wi-Fi Antennas, 2 x Internal full-band LTE antennas (700MHz ~ 2.7GHz)
    • Cellular: CAT 4
    • Battery: 5000mAh rechargeable battery
    • TF Card Slot: 1 x microSD card slot
    • USB Port: 1 x USB 2.0
    • Ethernet Speed: 10/100Mbps
    • Power Input: 5V/2A (with battery), 5V/3A (without battery)
    • Power Consumption: <4.4W
    • Dimension / Weight: 120 x 74 x 28mm / 223.5 g
    • Puli (GL-XE300)
    • Ethernet cable
    • User manual
    • 5V/3A power adapter with US plug
    Frequently Bought Together🎁
    Product Initial Setup Guide
