We’re moving to a new website! Click to learn more >
This site closes on June 16, 2026, 11:00 PM (PDT).
We strongly recommend placing orders on the new website.*
Store Opening Sale
Save up to 20%
Explore New Store
Already have an account?
Activate Your Account
*Orders placed between June 15, 2026, 11:00 PM to June 16, 2026, 11:00 PM (PDT) will not earn loyalty points.
by GL.iNet
Sold out
Original price CAD 63.90 - Original price CAD 63.90
CAD 63.90
CAD 63.90 - CAD 63.90
Current price CAD 63.90
Version: GL-S10-POE
⚠️Before You Buy
GL-S10 BLE IoT Gateway
MEET GL-S10
Connecting IoT Devices to the Cloud
BLE IoT Gateway
GL-S10 is an ESP32-powered BLE to MQTT IoT gateway. It can be used to facilitate communication between your beacons and servers, such as MQTT broker and AWS IoT. GL-S10 also comes with an optional beacon for testing and a tool app for fast and easy deployment.
Built-in BLE Module
Support MQTT and PoE Power Supply
Built with ESP32
*This product cannot be used as a WiFi Access Point
Learn More
How GL-S10 Works
The GL-S10 is an IoT gateway device that supports BLE and Wi-Fi, providing a cost-effective solution for transmitting BLE broadcast data to the cloud. BLE supports GAP and GATT certification. GL-S10 can use Wi-Fi as a Station to connect to a parent route or can connect to the Internet through a WAN port. It has a built-in standard MQTT Client that can connect to any standard MQTT Servers to forward incoming BLE messages to the cloud server.
How S10 Works
ESP32-D0WD Chipset
ESP32 is a single-chip integrated with 2.4GHz Wi-Fi and BLE. It features ultra-high RF performance, with high stability, versatility, and ultra-low power consumption. GL-S10 is suitable for a wide variety of application scenarios.
GL-S10 deployed in warehouses
A Minimalist IoT Communication Solution
GL-S10 is a compact BLE IoT gateway that supports Wi-Fi and MQTT protocols. It is designed to be an essential, low power consumption and low-cost transmission device.
Bluetooth 4.2
BLE 4.2
AWS IoT
AWS IoT
PoE
PoE
MQTT
MQTT
Real-time Scanning
Real-time Scanning
Wi-Fi 150Mbps
Wi-Fi 150Mbps
  • CPU: ESP32-D0WD
  • Memory / Storage: SRAM 520KB + PSRAM 8MB / NOR Flash 4MB
  • Protocol: IEEE 802.11b/g/n
  • Wi-Fi Speed: 150Mbps (2.4GHz)
  • Antennas: SMA external antenna
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: N/A
  • Ethernet Port: 1 x Ethernet port
  • Ethernet Speed: 10/100Mbps
  • Power Input: Micro USB, 5V/1A or PoE Power Input
  • Power Consumption: < 0.5W
  • Dimension / Weight: 57 x 57 x 25mm / 53.6 g
  • GL- S10 Gateway
  • External Antenna
  • USB Cable
  • User Manual
Product Initial Setup Guide
