New Arrival: High Performance KVM Over Wi-Fi
Pre order--Marble (GL-B3000) Wi-Fi 6 Dual-Band Gigabit Router
Sold out
Original price CAD 109.00
Original price CAD 109.00 - Original price CAD 109.00
Current price CAD 77.00
CAD 77.00 - CAD 77.00
⚠️Before You Buy
Transform your living space with the Marble (GL-B3000), a Wi-Fi 6 home router featuring a minimalist design and photo frame. At GL.iNet, we believe a router should do more than just connect devices; it should also bring families closer together. Our innovative design philosophy prioritizes emotional connections and meaningful interactions. The Marble is crafted to meet the unique needs of every family, enhancing your bonds and ensuring data security, all within a sleek, minimalist design that fits seamlessly into any home decor.
Product Description:
  • Fast Wi-Fi Performance and Comprehensive Coverage: The Marble supports Wi-Fi 6 technology, delivering a stable and reliable internet connection with high speed and performance. Experience AX3000 Wi-Fi speeds with up to 574 Mbps on the 2.4GHz band and 2402 Mbps on the 5GHz band. Additionally, the Marble functions as a stand-alone router or an Access Point (AP) to extend your existing network's coverage, ensuring comprehensive connectivity throughout your home.
  • Enhanced Security and Functionality: The Marble offers wide VPN support with preinstalled configurations for over 30 VPN service providers, including OpenVPN (up to 30 Mbps) and WireGuard (up to 190 Mbps) protocols, securing all connected devices. Additionally, the Drop-In Gateway Mode enhances your existing network with features such as parental controls, VPN, and AdGuard Home, extending the utility of your primary router.
  • Elegant, Space-Saving Design: The Marble is lightweight and portable, designed with a stand for easy placement that saves space without compromising performance. It includes a photo frame and a wall mount kit, allowing you to discreetly hide the router behind a customizable photo frame to seamlessly match your home decor.
  • Enhanced Parental Controls: The Marble collaborates with Bark to provide advanced parental controls, enabling easy management of screen time, content filtering, and safe browsing. For those who prefer local management, it also offers local parental control features at no additional cost.
  • Robust Connectivity: The Marble supports up to 90+ devices simultaneously, ensuring all your smart home gadgets, phones, tablets, and laptops stay connected and protected. It also features failover capability, automatically switching between Ethernet and Repeater modes if the network connection fails, ensuring continuous connectivity.
  • CPU: IPQ5018, Dual-Core A53 @1GHz
  • Memory / Storage: DDR3L 512MB / NAND Flash 128MB
  • Antennas: 4 x Internal Antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: N/A
  • Ethernet Port: 1 x WAN, 2 x LAN
  • Power Input: DC5521, 12V/1.5A (5.5*2.1mm)
  • Power Consumption: <13W
  • Dimension / Weight: Router: 155 x 120 x 23mm / 275g, Photo Frame: 235 x 197 x 32mm (Fits an 8-Inch Photo) / 275 g
  • 1 x Marble (GL-B3000) Router
  • 1 x Power Adapter
  • 1 x Ethernet Cable
  • 1x Converter
  • 1 x Wall-Mount Kit
  • 1 x Adhesive Pad
  • 1 x Router Stand
  • 1 x Photo Frame (Optional)
  • 1 x User Manual & Warranty Card
  • 1 x Thank-You Card
Product Initial Setup Guide
