Save 10% Save 10%
Original price CAD 177.99
Original price CAD 177.99 - Original price CAD 177.99
Current price CAD 160.99
CAD 160.99 - CAD 160.99
⚠️About ATX Board
⚠️Before You Buy
Remote KVM over PoE
PoE-Powered - Power & network over a single cable
Tailscale Support - Secure remote networking
32GB eMMC Storage - High-speed, built-in storage
Browser-Based Access - Remote control from Windows, macOS or Linux, no app required
4K@30FPS Video - Crisp visuals with H.264 encoding
Two-Way Audio - Hear and be heard remotely
One-time Purchase - No subscription fees, ever
PoE-Powered Remote KVM
32GB eMMC Storage
Two-way Audio
4K@30FPS Video
Tailscale Support
Dual Power Option
Self-Hosted Option
PoE & 1Gbps Ethernet
Deploy with a single cable for both data and power. Perfect for rackmount environments or minimizing cable clutter.
High-Speed 32GB eMMC Storage
Store system logs, snapshots, and even ISO installers with ~35MB/s reading speed-no external drive needed.
Browser-Based Remote Access
4K Video & Two-Way Audio
Mouse Controls
Mouse Controls
Comet PoE supports self-hosted deployment on mainstream operating systems such as Linux and Ubuntu, giving you full control over your remote access environment.
Comet PoE enables remote power management by connecting to extension devices such as ATX Boards and Fingerbot, allowing users to power on/off, or restart any device-even those without internet connectivity-from anywhere. By eliminating the need for physical access, Comet PoE reduces downtime, ensures seamless operation, and enhances efficiency, reliability, and cost-effectiveness.
10 Inch Rack Mount
Comet PoE in homelab setup
using Comet PoE for remote work while traveling
using Comet PoE in server rooms for reduced cable clutter
using Comet PoE in factories to cut hazardous site visits
Maximize Your Homelab with Local Storage & Full Control
With 32GB of onboard eMMC storage, Comet PoE provides ample space for system snapshots, recovery tools, and logging. Homelab users can manage headless servers or custom-built setups efficiently-no need for external storage or complex workarounds.
Manage systems in remote offices or offsite locations through a browser-no apps or complex VPNs required. Comet PoE is ideal for handling updates, troubleshooting, or BIOS-level access across distributed teams or locations.
Streamline Server Rooms with PoE-Powered Simplicity
Simplify deployment with Power over Ethernet (PoE)-just one cable for both power and data. Comet PoE helps IT teams reduce cable clutter and maintain a clean, organized environment, perfect for tight or dense server rack spaces.
Factories & Field Sites
Remotely monitor, control and troubleshoot multiple devices in high-risk or unmanned zones without site visits.
What Beta Tester are Saying
Comet PoE (GL-RM1PE) homelab setup with Slate Plus (GL-A1300) and Flint 3 (GL-BE9300) by beta tester
The upgraded 32GB eMMC lets me store ISO installers without hassle, and best of all, the latency is so low it feels like I'm physically connected to it. It's now a permanent addition to my laptop bag when servicing servers in cramped network closets where there's no room for a monitor or keyboard.
@OzTech74L
Comet PoE (GL-RM1PE) with Fingerbot (FGB-01) together for remote device access and management
I was looking for a solution to remotely manage my backup router which doesn't have IPMI.
Paired with a Fingerbot, this product is incredibly efficient and allows me to turn it on/off and control it using web interface. The POE power supply is a real plus, allowing me to take advantage of the UPS without using a dedicated electrical outlet.
@debian1604
Comet PoE (GL-RM1PE) used in homelab setup for remote device access and management
It's been very easy to use. Even my partner who struggled with tech worked it out in a few seconds. The design is very nice and I'll certainly be buying a couple when they go on sale. Nice work!
@yeloop
Comet PoE vs Comet- Core Specs & What's Different
Comet PoE(GL-RM1PE)
VS
Comet(GL-RM1)
Comet (GL-RM1)
32GB eMMC
Memory / Storage Storage
8GB eMMC
Quad-core ARM Cortex-A53
CPU CPU
CPU CPU
Quad-core ARM Cortex-A7
Write: ~25MB/s
Read: ~35MB/s
File Transfer Speed File Transfer Speed
Write: ~9MB/s
Read: ~10MB/s
30-60ms
Latency Latency
Latency Latency
30-60ms
1Gbps
Ethernet Speed Ethernet Speed
1Gbps
4K@30fps
Video Resolution Video Resolution
4K@30fps
PoE/USB-C
Power Options Power Options
USB-C
*Measured on internal tests; performance varies.
PoE
Power-over-Ethernet
4K@30FPS Video Resolution
4K@30FPS
Video Resolution
H.264 hardware encoding
with 30-60ms latency
BIOS Access
BIOS Access
USB 2.0 External Extension
USB 2.0
External Extension
Two-way Audio
Two-way Audio
APP or Browser Access
APP/Browser Access
Gigabit Ethernet
Gigabit
Ethernet
Technical Specifications
Interface 1 x Ethernet port (802.3af/at PoE support)
1 x USB 2.0 Type-A port (for extenal extension)
1 x USB 2.0 Type-C port (use as USB device)
1 x HD IN port
1 x Reset button
CPU Quad-core ARM Cortex-A53
Resolution 4K@30fps
Power Input Ethernet (PoE) / Type-C (Optional 5V/2A, PD-compatible)
Dimension 102 x 70 x 22mm / 140g
  • CPU: Quad-core ARM Cortex-A53
  • Memory / Storage: DDR3 1GB / 32GB eMMC
  • Power Input: Ethernet (PoE) / Type-C (Optional 5V/2A, PD-compatible)
  • Power Consumption: <5W
  • Dimension / Weight: 102 x 70 x 22mm / 140 g
  • 1 x Comet PoE(GL-RM1PE) remote KVM
  • 1 x USB 2.0 Type-A to Type-C cable
  • 1 x USB 2.0 Type-C to Type-C cable
  • 1 x Ethernet cable
  • 1 x HD cable
  • 1 x User manual
Expand Your Remote Control
Comet PoE (GL-RM1PE) User Guide
Comet PoE (GL-RM1PE) is the Power-over-Ethernet version of the Comet (GL-RM1), designed for simplified single-cable setups. The PoE model delivers both power and network connectivity via a single Ethernet cable, reducing cable clutter and simplifying installation, especially in hard-to-reach environments.
How to configure Comet PoE (GL-RM1PE)?
