Original price CAD 191.99 - Original price CAD 191.99
CAD 191.99
CAD 191.99 - CAD 191.99
Current price CAD 191.99
⚠️Before You Buy
Meet Beryl 7
BE3600 Dual-band Wi-Fi 7 Travel Router
GL.iNet's Fastest VPN Dual-band Wi-Fi 7 Travel Router
As a fully upgraded version of our Beryl AX, Beryl 7 is a compact dual-band Wi-Fi 7 travel router that delivers the fastest VPN speeds (up to 1,100 Mbps via WireGuard®) in GL.iNet's travel router lineup. With PD compatibility, it can be powered using a standard phone charger cable, which not only reduces the weight and clutter in your luggage, but also makes it much easier to keep your travel router powered up. Capable of supporting 120+ devices concurrently-all in a sleek, portable design built for life on the go.
Fast Wi-Fi speeds: Max. 688 Mbps (2.4 GHz) + 2,882 Mbps (5 GHz)
Robust VPN performance: Max. 1,100 Mbps on WireGuard® and Max. 1,000 Mbps on OpenVPN-DCO
Streamlined travel convenience: Universal USB-C charging compatibility
Versatile high-speed connectivity: Dual 2.5GbE ports and support for 120+ client devices
Wi-Fi 7
3600 Mbps
Dual 2.5G Ports
Boosted Wired Connections
Blazing-Fast VPN
Max. 1100 Mbps
PD Compatible
for True Mobility
USB 3.0
AdGuard Home
Multi-WAN Failover
OpenWrt-based SDK
Flexible Customization
How Does the Beryl 7 Fit Your Life?
Connect All Devices for the Price of One
Why pay a separate internet fee for every device? The Beryl 7 is your key to significant savings on the go. Simply connect it to the paid network once, and then share secure Wi-Fi with your phone, laptop, tablet, and more-all under a single access cost. Maximize your connectivity while you minimize your expenses and effortlessly bypass the captive portals with a one-time setup-no repeated logins required.
*Note: Travel routers may be prohibited by some cruise lines. Please check the specific regulations of your cruise line before use.
Stream Your Home Media, Anywhere
With Beryl 7, any hotel room can become your private theater. Connect to the hotel Wi-Fi, activate the built-in ultra-fast VPN client to access your home server, and plug in your streaming device or smart TV. Instantly, enjoy your personal media library and stream 8K content at high speed with complete privacy—as if you never left home.
File Sharing for Family Trips and Team Travel
Beryl 7 makes media and document sharing effortless during group travel. Connect an external USB drive to instantly create a private network storage space, supporting 120+ connected devices simultaneously. Family members or team members can securely access and share photos, videos, and work files—without relying on unstable public networks or limited cloud services. Everyone stays connected through a centralized, secure hub, making collaboration and memory-sharing seamless wherever you go.
Remote NAS Access & Backup on the Go
With Beryl 7 acting as a VPN client, you can securely connect back to your home network anytime, anywhere. Paired with the Brume 3 (GL-MT5000) at home, it enables seamless remote access to your NAS devices, letting you manage files, stream media, or even perform real-time photo backups directly to your home storage. This setup ensures your personal data remains private and protected over encrypted connections, while giving you LAN-like access as if you were physically at home.
Drop-Free Calls, Anywhere You Roam
For digital nomads, a reliable internet connection is essential. Beryl 7 can turn any location—a café, co-working space, or beachside apartment—into a secure, productive remote office. It ensures crystal-clear VoIP calls and stable video conferences, while a dedicated guest network keeps your main connection secure for client collaborations.
Secure Access to Your Internal Network
For business travelers, accessing company resources restricted to specific office IP addresses can be challenging. Beryl 7 solves this seamlessly. Pre-configured with OpenVPN and WireGuard, it can act as a VPN client to securely connect back to your office network, giving you access to internal systems, file servers, or managed printers—as if you were physically in the office—all over a fully encrypted connection.
Versatile Connectivity for Uninterrupted Access
Never settle for weak signals. Beyond multiple connection methods—including Ethernet, Wi-Fi repeating, and cellular tethering—Beryl 7 is truly smart. Its advanced Multi-WAN feature provides automatic failover, constantly monitoring networks and switching to the best available connection to prevent drops. This ensures a robust, private network with the consistent high performance needed for gaming, 8K streaming and other data-intensive tasks.
Transform Your MiFi into a Powerful Home Network
Beryl 7 can turn your MiFi or smartphone data plan into a high-performance Wi-Fi 7 network. Simply connect via USB and activate tethering mode, and it will receive the cellular signal and rebroadcast it as a superior Wi-Fi network throughout your space. With support for over 120 simultaneous connections, every device enjoys stable, high-speed internet—eliminating weak signals and connectivity limitations once and for all.
Unlock Global Content in Your Dorm Room
Beryl 7 lets you and your roommates bypass geographical restrictions simultaneously using a single VPN account. Supporting 30+ VPN service providers, this compact router provides seamless access to region-locked streaming services and video game platforms across all your devices. It also lets you apply VPN protection to the entire network or select specific devices, eliminating the need for individual per-device VPN subscriptions while ensuring everyone can enjoy their preferred content without compromise.
Encrypted Remote Access for Traveling Homelabbers and Media Lovers
For homelab enthusiasts and media collectors who travel, the Beryl 7 ensures your entire home network is always within reach. By establishing high-speed encrypted tunnels via WireGuard or OpenVPN, it provides seamless, secure access to your home servers, development environments, and personal media libraries from anywhere. This eliminates the risks of public internet exposure while delivering LAN-like responsiveness, letting you manage critical services or stream your movie collection as if you were locally connected.
Wire-free Control for Wired Devices
Beryl 7 enables seamless wireless control for Ethernet-only devices through a simple setup: connect the device to the router's LAN port and use your smartphone or tablet for wireless management. This compact solution is ideal for digital audio systems, mini-PCs, PLCs, and other equipment lacking native wireless capability. With flexible uplink options including Wi-Fi relay, Ethernet/USB tethering, plus built-in VPN support for secure data transmission, Beryl 7 provides a complete connectivity solution in a minimal footprint.
Beryl 7 (GL-MT3600BE) Reviews
  • BEST Travel Router!
    BEST Travel Router!
  • Gl.iNet Slate 7 PRO Travel Router Revealed
    The Newest Travel Routers...
  • Gl.iNet Beryl 7, Comet 5G and Flint 3e Revealed
    What Beta Testers are Saying
    slide 6 to 8 of 7
    Model Comparison
    Beryl AX (GL-MT3000)
    VS
    Reliable Wi-Fi 6 for Basic Travel Needs
    Positioning Positioning
    High-value Wi-Fi 7 for Speed and Affordability
    MediaTek, Dual-core @1.3GHz
    CPU CPU
    CPU CPU
    MediaTek, Quad-core @2.0GHz
    DDR4 512 MB / NAND Flash 256 MB
    DDR4 512 MB / NAND Flash 512 MB
    10/100/1000 Mbps
    LAN Ethernet Speed LAN Ethernet Speed
    100/1000/2500 Mbps
    574 Mbps (2.4GHz), 2402 Mbps (5GHz)
    Ethernet Speed Wi-Fi Speed
    688 Mbps (2.4GHz), 2882 Mbps (5GHz)
    Max. 300 Mbps
    OpenVPN-DCO Speed (Via Ethernet) OpenVPN-DCO Speed (Via Ethernet)
    Max.1000 Mbps
    Max. 300 Mbps
    WireGuard® (Via Ethernet) WireGuard® (Via Ethernet)
    Max.1100 Mbps
    Type-C, 5V/3A
    Power Input Power Input
    Type-C, 5V/3A, 9V/3A, 12V/2.5A
    120 x 83 x 34mm / 196g
    Dimension / Weight Dimension / Weight
    120 x 83 x 34mm / 205g
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    Tri-band Wi-Fi 7
    Wi-Fi 7
    VPN Client / Server
    VPN Client /
    Server
    2.5G Ethernet Ports
    Dual 2.5G
    Ethernet Ports
    USB 3.0 Port
    USB 3.0 Port
    Multi-Link Operation
    Multi-Link
    Operation
    Partenal Controls
    PD Power Supply
    (5V/3A, 9V/3A, 12V/2.5A)
    Partenal Controls
    DNS Encryption
    Technical Specifications
    1 x LAN Ethernet port
    1 x USB 3.0 port
    1 x Type-C Power port
    1 x Reset button
    1 x Toggle button
    Memory / Storage DDR4 512MB / NAND Flash 512MB
    Wi-Fi Speed 688Mbps (2.4GHz), 2882Mbps (5GHz)
    Antennas 2 x foldable external Wi-Fi antennas
    Power Input Type-C, 5V/3A, 9V/3A, 12V/2.5A
    Power Consumption <12W (without USB)
    Dimension / Weight 120 x 83 x 34mm / 205g
    Tools & Downloadables Firmware | App | Unboxing | Tutorials | Media Kit
    • CPU: MediaTek, Quad-core @2.0GHz
    • Memory / Storage: DDR4 512MB / NAND Flash 512MB
    • Wi-Fi Speed: 688Mbps (2.4GHz), 2882Mbps (5GHz)
    • Antennas: 2 x foldable external Wi-Fi antennas
    • Cellular: N/A
    • Battery: N/A
    • TF Card Slot: N/A
    • USB Port: 1 x USB 3.0 port
    • Ethernet Port: 1 x WAN Ethernet port; 1 x LAN Ethernet port
    • Power Input: Type-C, 5V/3A, 9V/3A, 12V/2.5A
    • Power Consumption: <12W (without USB)
    • Dimension / Weight: 120 x 83 x 34mm / 205 g
    • 1 x Beryl 7 (GL-MT3600BE) Router
    • 1 x User Manual
    • 1 x Thank You Card
    • 1 x Power Cable
    • 1 x Ethernet Cable
    • 1 x US Power Adapter
    • Converters (EU,UK and AU Plugs)
    Step 2: Choose your sensor 🌟
    👉 Compare
    💡Remember to add the Smart+ sensors to your cart. They're the must-have to unlock all the features!
    Product Initial Setup Guide
