Limited-Time Flash Sale: Save Up to 20%!
Original price CAD 246.99 - Original price CAD 246.99
CAD 246.99
CAD 246.99 - CAD 246.99
Current price CAD 246.99
15% off
Auto discount on add-to-cart
*Pack discount excluded
Wi-Fi 6
Unleash mobility, free from Ethernet cable
2.22-inch Touchscreen
4K Video Passthrough
Quad Core
CPU
32GB eMMC
DDR3L 1GB
Ultra-low Latency
Gigabit LAN (1Gbps)
Self-hosted Server
Why Do I Need a KVM
Why Do I Need a KVM
The Comet Pro
Wi-Fi 6
Comet Pro is the first desktop KVM device to support both 2.4GHz and 5GHz Wi-Fi bands. Connect your GL.iNet Comet Pro (GL-RM10) to your Wi-Fi network without needing a LAN connection, redefining flexibility in remote access. Users can now manage systems without the need to connect physical network cables, unlike traditional KVM solutions. Additionally, the Comet Pro allows for network failover with both Wi-Fi and ethernet capabilities to improve your uptime stability.
Dual Band Wi-Fi 6
Total System Control
Accessories
PoE Splitter
PoE Splitter
Travel Case
Travel Case
TechRadar
TechRadar
Comet Pro Product Reviews
    I NEEDED to Fix her Internet!
What Beta Tester are Saying
The product feels premium to touch and the UI is very good, both on device and the web UI. The ease of use is astonishing. I could set the whole thing up in 5 minutes without having to read or google something AND without having ever used a KVM before.
@uranioh
I have loved working with this device, its made remoting onto any of my servers or end user computers miles easier and when using the web app, everything is really smooth. I experienced no latency issues or connectivity issues whilst carrying out any of my testing.
@Zwytch
As an IT field engineer, the Comet Pro has become my go-to tool for accessing servers and systems that lack out-of-band management. It’s compact, reliable, and surprisingly versatile.
@OzTech74L
The GL.iNet Comet Pro really delivers on what modern remote access users want. The 2.2-inch touchscreen is surprisingly handy for quick status checks and setup without opening a browser. Features like Virtual Media/ISO mounting, BIOS-level control, and remote file copying make it far more flexible than most remote KVM boxes.
@Mniko
Compare KVM
Home Lab Comet (GL-RM1)
Comet
 (GL-RM1)
KVM over Internet
Comet PoE
 (GL-RM1PE)
KVM over PoE
Comet Pro
 (GL-RM10)
KVM over Wi-Fi 6
Display
4K@30FPS
4K@30FPS
4K@30FPS
Latency Latency
Latency Latency
30-60ms*
Latency Latency
30-60ms*
Latency Latency
30-60ms*
Two-way Audio Two-way Audio
HD Passthrough HD Passthrough
Display Screen Display Screen
2.22" touchscreen
System & Connectivity
Processor Processor
Processor Processor
Quad-core Cortex-A7
Processor Processor
Quad-core Cortex-A53
Processor Processor
DDR3L 1GB / 8GB eMMC
DDR3L 1GB / 32GB eMMC
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
2.4GHz: 286Mbps
5GHz: 286Mbps
LAN Port LAN Port
LAN Port LAN Port
1Gbps
LAN Port LAN Port
1Gbps
LAN Port LAN Port
1Gbps
Power Input Power Input
Type-C, 5V/2A
Ethernet (PoE) / Type-C,
5V/2A, PD-compatible
Type-C, 5V/2A,
PD-compatible
Dimensions Dimensions
80 x 60 x 17.5mm / 85g
102 x 70 x 22mm / 140g
93 x 84 x 47mm / 170g
Wi-Fi 6
Wi-Fi 6
4K@30FPS Video Resolution
4K@30FPS
Video Resolution
H.264 hardware encoding
with 30-60ms latency
BIOS Access
BIOS Access
USB 2.0 External Extension
USB 2.0
External Extension
Two-way Audio
Two-way Audio
APP or Browser Access
APP/Browser Access
Gigabit Ethernet
Gigabit
Ethernet
Technical Specifications
Operating System Linux 6.1
CPU Quad Core ARM Cortex-A53
Resolution 4K@30FPS
1x Gigabit Ethernet port
1x HD In
1x HD Out
1x USB 2.0 Type-A
Remote Control Accessories
