Slate 7 Pro (GL-BE10000) | Tri-band Wi-Fi 7 Travel Router
Original price CAD 329.99 - Original price CAD 329.99
CAD 329.99
CAD 329.99 - CAD 329.99
Current price CAD 329.99
Type: GL-BE10000NA
⚠️Before You Buy
World's First True Tri-band Travel Router
Slate 7 Pro (GL-BE10000) is the world’s first travel router to redefine the limits of networking by unleashing the full power of tri-band Wi-Fi 7 aggregation. Equipped with an intuitive 2.8" touchscreen, it allows you to manage key network functions with a single tap. Beyond speed, it provides pro-grade security through integrated DPI and high-speed VPN to safeguard your privacy in any environment. With Slate 7 Pro, you don’t just connect to the world—you challenge its boundaries. Choose your office, secure your data, and embrace the freedom to work from anywhere without compromise.
Tri-band Wi-Fi 7 with MLO: Faster and more stable connections using tri-band aggregation and Multi-Link Operation.
Intuitive 2.8" Touchscreen: Real-time monitoring and one-tap basic network management.
High-Speed VPN with Obfuscation: Up to 1100 Mbps (WireGuard®) with obfuscation to bypass restrictions.
Advanced Network Security: Integrated DPI to easily identify and block malicious traffic.
OpenWrt Customization: OpenWrt support for professional-grade flexibility and plugin support.
Seamless Wired Connectivity: Dual 2.5G ports and a versatile Type-C 3.0 data port.
Wi-Fi 7
Advanced Tri-Band Connectivity
Blazing-Fast VPN
Max. 1100 Mbps
Smart Touch Interface
VPN Obfuscation
Bypass Traffic Inspection
OpenWrt-based SDK
Flexible
Customization
Advanced
DPI Shield
Tri-band Aggregation
Dual 2.5G Ports
Boosted Wired Connections
Multi-WAN
Failover
One-Tap Network Control
Slate 7 Pro makes networking effortless with its responsive 2.8" touchscreen. Manage essential features directly on-device to save time and effort. Instantly toggle VPNs, share Wi-Fi, and monitor status with a single touch, giving you immediate control the moment you power on.
Get Started Instantly, No App Required
From Power-On to Connection—No App Required
Toggle VPNs and Switch Providers in Seconds
Pro DPI Security, Compactly Delivered
Slate 7 Pro delivers professional-level precision in a sleek, compact design. By integrating Deep Packet Inspection (DPI), it moves beyond basic tracking to analyze data in real-time—giving you the power to monitor and protect your network, anywhere.
Intuitive Traffic Insights with Visual Precision
Smart Web & Content Filtering
Optimized Bandwidth Management
Stable Connections for Critical Tasks
Professional Network Sovereignty for Remote Teams
Enterprise-Grade Security for Family & Small Business
Seamless Connectivity for Virtual Collaboration
Stable Performance for Critical High-Load Tasks
Always-On, High-Speed Networking
Slate 7 Pro features dual 2.5G ports—including one configurable WAN/LAN—and a USB-C port for tethering, enabling fast, flexible connectivity with seamless Multi-WAN failover.
Mission-Critical Reliability for Business Travel
High-Bandwidth Production in the Field
Professional-Grade Home Lab & Remote Work
Unlock Flexible, Customizable Networking
Built on OpenWrt 21.02 (Kernel Version 5.4.281) with 1GB DDR4 RAM and 512MB NAND Flash, Slate 7 Pro provides the freedom to evolve the router’s capabilities through extensive plugin support and deep customization.
Tri-band Wi-Fi 7
Tri-band Wi-Fi 7
Touchscreen
Touchscreen
DPI
DPI
Multi-Link
Operation
VPN Client Server
VPN Client /
Server
OpenWrt Support
OpenWrt
Support
Dual 2.5G Ethernet Ports
Dual 2.5G
Ethernet Ports
PD Power Supply
PD Power Supply
Specifications
Interface 1 x 2.5G WAN Ethernet port
1 x 2.5G LAN Ethernet port
1 x USB 3.0 Type-C port
1 x Type-C Power port
1 x Reset button
1 x Toggle button
Memory / Storage DDR4 1GB / NAND Flash 512MB
Antennas 2 x foldable external Wi-Fi antennas
Power Input USB PD 5V/3A, 9V/3A, 12V/2.5A
Power Consumption <20W (without USB)
Dimension / Weight 130 x 91 x 36mm / 328g
  • CPU: MediaTek, Quad-core @2.0GHz
  • Memory / Storage: DDR4 1GB / NAND Flash 512MB
  • Wi-Fi Speed: 688Mbps (2.4GHz), 2882Mbps (5GHz), 5764Mbps (6GHz)
  • Antennas: 2 x foldable external Wi-Fi antennas
  • Cellular: /
  • Battery: /
  • TF Card Slot: /
  • USB Port: USB 3.0 Type-C port
  • Ethernet Port: 1 x 2.5G WAN Ethernet port; 1 x 2.5G LAN Ethernet port
  • Power Input: USB PD 5V/3A, 9V/3A, 12V/2.5A
  • Power Consumption: <20W (without USB)
  • Dimension / Weight: 130 x 91 x 36mm / 328 g
  • 1 x Slate 7 Pro (GL-BE10000) Router
  • 1 x User Manual
  • 1 x Thank You Card
  • 1 x Power Cable
  • 1 x Ethernet Cable
  • 1 x Power Adapter with Converters (US,EU,UK and AU Plugs)
Product Initial Setup Guide
